Electrical Guru's needed...
Old Jun 21, 2009 | 06:57 PM
silly34's Avatar
silly34
Summer is here and it is frkn hot! I have 4 horses that like to stand in the barn. I put up 4 box fans that run 24x7 (horses appear to love the wind to keep the flys off), today I decided to try to wire a motion sensor so the fans wouldn't run when the horses weren't in the barn. It worked but not like I had wanted. I used a motion sensor that is used on flood lights.. apparently it can't pump out the amps that the fans need for them to run efficiently. The whole setup worked fine except the output.
So I now I was thinking I could keep using the motion sensor but wire it into a relay instead? But I'm not sure what type of relay to get (for AC Voltage) or where to get it from.
Suggestions!?
B.
Old Jun 21, 2009 | 07:07 PM
ckal704's Avatar
ckal704
Go to your local electrical supply house (look in the Yellow Pages) and tell them what you are trying to do. They'll fix you right up if they are anything like the guys near me.
Old Jun 21, 2009 | 08:27 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Do you have a Grainger industrial supply near you?
You don't say how much current the 4 fans use in start and run, or even what voltage they are.
So there's no recommendation on that question.
Old Jun 21, 2009 | 08:34 PM
silly34's Avatar
silly34
Haven't had a chance to go back out to look at the motors but they are the cheap $15 dollar fans that supposedly only cost $.02 an hour to run. I found a relay that will work 1/3hp and another up to 1hp from Grainger.
B.
Old Jun 22, 2009 | 07:46 AM
megawatt00's Avatar
megawatt00
Use the motion sensor to run a relay. A motion sensor for a light fixture has a very low ampere rating. If you need help with a wiring diagram just shoot me a pm.
Old Jun 22, 2009 | 08:27 AM
stormyrider's Avatar
stormyrider
Local electrical supply house would carry relay and relay socket. When sizing the relay add up the full load amps of all the fans motors and add 20% to protect the relay contacts. most motion sensors are not designed for a lot of power to flow through but a properly sized relay will do the trick.
Old Jun 22, 2009 | 10:28 AM
websthes's Avatar
websthes
Why do you want the fans to turn off? A fan doesn't use that much power. And I find they're more effective when you leave them running.
I would put all four fans on a timer and have them run when the sun is out.
If you want a heavy duty timer, Canadian tire sells them for our block heaters. Those things are like 1500 watts.
Old Jun 23, 2009 | 04:58 AM
angus's Avatar
angus
You could do it with X10 stuff. They've got motion sensor modules, and "appliance" modules that'll handle plenty of amps.
X10.com - Security Cameras, X10 Home Security, Wireless Camera, Home Automation, Electronics and More!
Old Jun 24, 2009 | 01:17 PM
bpounds's Avatar
bpounds
A relay of size enough to run motors is often called a contactor.
Unless your horses are unusually animated while standing around, a motion detector is not going to keep them happy. Suggest you consider a timer instead, that turns the fans off at night when it is cooler. Or else a sunlight sensor placed outside the barn.
You'll still need the contactor. You want one rated for inductive loads, because motors will burn up the contacts of relays not rated for same.
Old Jun 24, 2009 | 01:39 PM
silly34's Avatar
silly34
Got everything wired in and it has been working great. I appreciate all of the suggestions!
B.
Frapper
Aug 7, 2012 08:08 PM
Racerguy
Jul 4, 2011 08:19 AM
scottie2hottie
29
Sep 7, 2008 04:14 PM
924x2150
52
Jan 10, 2006 06:53 AM
TallPaul
18
Aug 20, 2003 07:29 AM
