efi problem no start please help
Old Jun 21, 2009 | 01:09 AM
chasingmytail's Avatar
chasingmytail
if anyone is online and thinks they can help i will gladly give a rundown of all the troubleshooting that i have already done
Old Jun 24, 2009 | 11:25 AM
300 Buster's Avatar
300 Buster
The first thing I would check is fuel,are you getting any? If not ,could be inertia switch under dash needs reset, fuel pump relays go bad,do you hear your fuel pump run when you turn the key on?If not,that's your problem,with EFI they won't even grunt when the fuel stops.Water in gas maybe?,might plug up filter.If you have fuel,then I would star looking for spark,pull a wire off and connect it to a plug that you know is good,ground the plug and grind it over,DON'T grind it over with nothing in the wire,I'm not sure about these,but with some ignitions,this will damage components.Beyond this,you may want to check your codes and that is over my head,but maybe some of these guys on here can help you out.
