Sponsored by: Real Truck
Relay wiring
Old Jun 20, 2009 | 05:26 PM
Headviking's Avatar
Headviking
Relay wiring
I would like to use this relay to install rear backup aux. lights. The only thing I do not know is whitch prong is for what? Can anyone help?
Old Jun 20, 2009 | 05:40 PM
MikeMcCasland's Avatar
MikeMcCasland
On my 2004 it was a black w/ pink stripe wire on the chassis wiring. It was probably a 18-20ga wire.
https://www.cvpi.com/truckbbas/topic...lectrical.html
Those PDF's should help you.
http://www.accessconnect.com/trailer_wiring_diagram.htm
Old Jun 20, 2009 | 06:08 PM
ReAX's Avatar
ReAX
If you have a relay with the numbers marked on it, here's the cheat sheet.
85 coil ground
86 coil positiver (these two can be switched, unless there is a spike suppression diode in it.)
30 is the common pole (it flips between 87 and 87a)
87 is the switched position (when the coil is hot, 30 and 87 are connected)
87a is the at rest position (when the coil is not powered, 30 and 87a are connected.)
So you need to ground the 85 terminal and run the 86 to the backup 12+v wire. the relay will now click.
Then it's 30 to the lights and 87 to the battery/fuse.
Old Jun 20, 2009 | 07:37 PM
Headviking's Avatar
Headviking
Thanks the was the one.. Got it up and everythings working
