While cleaning my engine bay today I saw that my drivers side IC pipe was off. I don't know how long its been off. what kind of damage is possible from that? what can I check? It seems to be running normal still.
Thanks,
Mike
Are you sure it was completely off before you started cleaning? When its off you won't be making any boost and will smoke like a train. Your egts can get really high fast, but if you have guages you would have noticed I am sure. You are probably fine besides building up a little extra soot to blow out
I don't have gauges so I might have pushed it off somehow but I'm not sure. No smoke though...
Ford should have included guages with these things! But yes, like they said, you should be fine. You can miss the smoke that bellows out worse then a train
I was trying to drive a big rig with a broken intercooler. It was not cool, it smoiked real bad and had 00000 power. I felt like I could push it faster...
I blew one off also on one of our rigs, the clamp snapped, dead in the water I was.
