Couple 350 questions
Old Jun 20, 2009 | 12:38 AM
bmxstreet15's Avatar
bmxstreet15
So i just successfully replaced my inner axle seals. I happened to notice a metal bracket on my axle housing that appears to be a steering damper mount. Is there any way I could get the damper along with the parts i need to install it? If anyone has a picture of how it is set up from the factory I would be able to determine if that is what the bracket is for.
My next question is can I run a ts chip with my stock injectors? If not, will I need to change my HPOP to run stage ones? I was thinking about using Jims DIY kit IF I have to up the flow of my injectors.
Old Jun 20, 2009 | 06:21 AM
Talyn's Avatar
Talyn
You can chip with a stock setup.
Old Jun 20, 2009 | 10:21 PM
Passin Thru's Avatar
Passin Thru
Not sure what you're looking at but sounds like an anti sway bar bracket or it could be a damper. You probably don't need it because 350s don'tsway much and better thana damper is to put AIRRIDE 1000 or 5000 on it. Same price, better ride.
