tranny question?????
Old Jun 18, 2009 | 05:00 PM
spongebobsf100's Avatar
spongebobsf100
would a 5 speed tranny from 2002 5.0 mustang bolt up to my 351m??? with out changing the bell housing.
Old Jun 18, 2009 | 09:53 PM
inxquve's Avatar
inxquve
The only engine options for an '02 Mustang were a 3.8 and three versions of the 4.6, no 5.0. Either way, the answer to your question is, unfortunately, no.
Old Jun 19, 2009 | 05:23 AM
jowilker's Avatar
jowilker
What he said, no. Not even close.
Find something that will work on a 460 (385 series) and you will be on the right path.
John
Old Jun 19, 2009 | 11:20 PM
spongebobsf100
oo yeah lol. wasnt realy thin king when i said 5.0.
and do you know any good manual trans that will fit the 351m??
Old Jun 19, 2009 | 11:29 PM
85e150's Avatar
85e150
Actually, most Mustang transmissions--the ones without an integral bell--can be made to fit nearly any engine. But that does not mean they would be a good choice here, and you would probably need a different bell or an adaptor.
Your engine uses the same pattern as the 385 series, the 429/460. Thus, a ZF from a 460 truck can be used. This may require a hydraulic clutch, although I think 460s used an external slave set up (IIRC, CRS tonight)
Is this for truck work, or performance? Towing?
Old Jun 19, 2009 | 11:44 PM
spongebobsf100
its kinda show and performance.
Old Jun 19, 2009 | 11:46 PM
85e150's Avatar
85e150
OK, so what is the condition of your 351m? Bone stock dogged out 139 hp smog motor stocker? Or stroked and poked updated firebreather?
Old Jun 20, 2009 | 01:16 PM
spongebobsf100
it only has a diffrent intake manifold and a eldelbrock 4 barrel carb that i know. i think the motor came out of a T-bird not sure though
Old Jun 20, 2009 | 07:19 PM
85e150's Avatar
85e150
What trans do you have now?
Budget? This gets expensive quickly.
Old Jun 21, 2009 | 12:28 AM
spongebobsf100
the tranny i have now is c6. i just want to know what trannys would bolt up to my 351m.
Old Jun 21, 2009 | 06:16 PM
85e150's Avatar
85e150
Anything you like, if you buy the right bell housing. Figure $500 for a scatter shield, and they will drill it for what you want.
Otherwise, a Ford bell will have the Ford "butterfly" pattern. There are two depths, and truck transmissions like the NP435 or T18/19 will bolt up to one, and car transmissions like the top loader 4 speed or T5 will bolt up, although the T5 will require an adaptor.
Modern Driveline - T5 / TREMEC TKO Transmission Conversion - 5 speed & 6 speed solutions to swap your Ford Mustang, Falcon, Cobra, Hotrod into Overdrive! Performance Parts
There is no "performance" to be had in the truck transmissions, and like I said, the 5 speed or toploader set up is going to get expen$ive fa$t.
