hey guys, i have a 88 f250 with a I6 in it. i had some troubles with it and wasn't getting any spark. i checked and had power to the coil and then to the plug on the ignition module, but no spark. so today i bought the little socket for the module and took it in to have bench tested. it was bad, they gave me a new one. the one they gave me was grey. and the old one was grey. i put it on and had spark, but would not fire. i had also put new cap and rotor and plugs in so thought i had messed up my firing order. so i messed with that till one time i tried and it fired right up. ran for a few minutes and as soon as i stepped on the gas it miss fired and died. i then tried a diferent firing order and it started up. i drove it to work and at one point it was missing again and i pulled over and it went away and i was off to work.
on my way home today it started right up, got a couple blocks and it was missing again and died. i went one over ont he firing order and it started right up and i got about 5 more blocks and died again. this time my battery is also dead from trying to start it. any ideas why it would start up and run for a bit and then start messin up again? could it be a bad ignition module? coil?
my dist cap doesn't have anything to say where number 1 wire goes?
this is driving me crazy, been messin with it for a week now and finally got it runningand then this.
any help would be super great.
thanks
