Guys, here's my Crew Cab F150 that I inherited from my grandfather. I brought it home and it sat for a while. I've been so wrapped up in my diesel stuff, I hadn't had a chance to do anything with it. But I finally found time to do a 40/20/40 front seat swap, and today I gave it it's first mod. Tinted windows. Hurray!!! Anyway, this is the same truck I asked a while back about the sagging front end. I still don't have a solution to it. But I haven't tried anything either. Anyway, you guys let me know what you think.
IMHO, Shocks have nothing to do with the stance, just the ride/handling while in motion. And yes, mine sits lower in the front, and when I back up to park, my front-end splays out and seems to toe-in. I always had a question about that, but never got around to ask about that here. I suppose it's a camber issue. (Drives perfect, though...)
It's most likely a Centurion, I agree. There was another company doing F150s like this, but Centurion is by far the most common. Since they were sold right on dealer lots and could be ordered from dealers, a lot of folks think they're factory.
I'd say the front suspension is in need of an overhaul, it is squatting for sure. You can try getting beefier components, but the truck is still 14-15 years old, you'll see some droop in that period of time.
I personally wouldn't lower the truck, since it's not a reg cab 2wd shortbed or flareside, but I would see about getting the dent in the door and bed pulled and the front suspension refreshed.
Enjoy your rig, it's a keeper.
I beg to differ. I had Rancho RS5000 shocks on my truck and now have Rancho RSX shocks on my truck. The RSX is gas charged the 5000 is not its more of just a dampener. Gas charged shocks push out wards. My truck sits about 1/4 to 1/2 inches higher with the RSX schocks. We also noticed the same thing oun our old 85 F150 when we replaced its worn out shocks with Monroe gas charged shocks.
The front end squatting down more when backing up is just how the twin I beam setup works I think. I see alot of our era trucks do that.
Hell. If ya put some lowering springs in the rear to "level"it out, it would look good
That would be cool since its a 2wd. I actually thought about lowering the rear of mine. All he would need for that are the 1-2 inch lowering shackles. Then the truck would retain the payload capacity.
the guy who built the white 4dr had one bad a s s copper lightning and that is going to be his tow pig.
While no one ever built a 4 door lightning there were quite a few supercab short bed lightnings made by a company called Full Effects. I think a 4 door lightning clone would be bad a s s
