Help running vacuum lines
Old Jun 16, 2009 | 06:39 PM
91Bronc300's Avatar
91Bronc300
I just installed a propane system on my 1985 F-250 with a 300 and I need some ideas on getting the vacuum lines run. The base plate I used for the IMPCO mixer only has two full manifold vacuum ports. One little one for the dizzy advance, which I'll just use for the dizzy advance, and one larger one, I think 5/16. I need to use this single large port for the brake vacuum booster, the PCV, and the transmission modulator signal. All three hoses are different sizes. The local auto parts store only has tees of the same size. Does anybody know of a good way to split this single port off into three ports of all different sizes? Is there some sort of vacuum 'rail' I can buy online somewhere that has a bunch of various port on it and I could just plug the ones I don't need? I could use some extra brains on this one. Thanks
Old Jun 16, 2009 | 07:47 PM
91Bronc300's Avatar
91Bronc300
Ok, I guess I posted a little early, I just saw some stepped vacuum connectors on Autozone.com. Guess that's where I'm heading tomorrow
shaw4825
Apr 13, 2012 10:32 PM
koolwav36
Oct 2, 2010 05:02 PM
86rustbucket
Feb 17, 2004 06:52 AM
cdherman
Sep 27, 2003 12:11 AM
gadams
Aug 22, 2002 09:25 PM
