friction modifier in E4OD?
Old Jun 16, 2009 | 05:34 PM
dougflaxseed's Avatar
dougflaxseed
Hey everyone, I'm new to the forums and new to Ford, after being a Chev man the last 16 years.
I have been driving my my 1993 f-150 with 302/E40D for about a month now. It's starting to shudder quite bad especially when I'm cruising between 47-49 kms/hr. I read somewhere that people have had success adding Motorcraft Friction Modifier additive to cure this. I know it's intended for rear ends but some places I've read of people adding it to the trannys to rid them of shudder? Is this safe for the E4OD's?
Thanks for any help, great forum guys,
Brad
Old Jun 16, 2009 | 05:38 PM
Jermafenser's Avatar
Jermafenser
Have you checked the trans fluid for its level and condition? That would be the first thing I'd look for.
Personally, I wouldn't put in friction modifier...you do NOT want to rebuild a E40D if you can help it!
Old Jun 16, 2009 | 06:18 PM
dougflaxseed
I changed the fluid and transmission filter in May. I drove the truck from Ontario to New Brunswick with no problems. It started shortly after that, within the last month. I'm leary of using additives too, but saw someone write how one 4 oz bottle of friction modifier cured the shudder in any Ford they had tried it on.
Brad
Old Jun 16, 2009 | 06:23 PM
subford's Avatar
subford
I have used it in the 4R70W and read where others have too but I have not heard of anyone doing it with a E4OD.
Note that if you put in Mercon V ATF it already has it in it.
Old Jun 16, 2009 | 06:26 PM
quicklook2's Avatar
quicklook2
did you drain the convertor?
i bet you did not.
that is where 60-70% of the fluid that is bad was.
1. drain convertor
2. drain pan and replace filter/pan
3. new name brand fluid.
optional: bottle of lucas trans fluid
or optional: dr. trans shudder fixx (google it)
then your shudder will be gone for good.
Old Jun 16, 2009 | 06:38 PM
dougflaxseed
My brother did the fluid/filter change just before I picked up the truck at his place. You're probably right, I doubt he drained the convertor. Should I take it in where they can hook it up to a machine to flush it? Perhaps the Ford dealer?
Brad
Old Jun 16, 2009 | 07:28 PM
jr32560's Avatar
jr32560
i had mine done like that once-it's costly -i do it my self now -just pull the inspection plate and spin the converter till ya see the drain plug-lucas is one good product-have used it many times!
Old Jun 16, 2009 | 08:17 PM
quicklook2's Avatar
quicklook2
leave the inspection plate on.
you drain an e4od from the plug at the bottom of the case below the convertor.
do what i said in my last post.
no power flush is needed.
especially at the ford dealer.
get a big pan, these trans hold a lot of fluid.
Old Jun 17, 2009 | 05:59 AM
Midwest Dually's Avatar
Midwest Dually
Now how do you drain the converter? This may sound retarded, but I am used to manual trans, not ATX. I am having minor issues with my E4OD as well, but not in shudder.
Old Jun 17, 2009 | 08:14 AM
Jermafenser
There's a drain plug in the converter. You may have to 'bump' the engine in order to get to the drain plug.
Old Jun 17, 2009 | 08:33 AM
quicklook2's Avatar
quicklook2
like i said, remove rubber plug, then you bump engine until drain lines up.
if you need more info then in this thread, do an advanced search.
Old Jun 25, 2009 | 11:58 PM
dougflaxseed
Thanks for the advice on the fluid change. The truck started shaking worse and worse until I could barely drive it. I found my two month old plug wires were coming apart at the crimps I replaced them with Motorcraft wires routed as shown in other posts on the forum. The "tranny problem" is now fixed
Brad
Old Jun 26, 2009 | 03:59 AM
TexasGuy001's Avatar
TexasGuy001
Brad
DO NOT use the transmission flush machine. It will just cause more problems. Mine actually ran a little funky about a month after I got it 10 years ago. It had 80k miles on it then. I gave it a complete tune up and found that the plugs were shot.
Old Jun 26, 2009 | 09:17 AM
6CylBill's Avatar
6CylBill
Brad
Nothing useful to add, I just wanted to welcome you to FTE and Ford trucks!
Old Jun 26, 2009 | 09:42 AM
quicklook2's Avatar
quicklook2
first thing to do when getting a new vehicle is to go over it and fix what needs to be fixed.
glad the wires helped.
i hope you did a complete tuneup and still plan to do the fluid/filter in the trans.
