One of the panels in the dash has had some type of mounting adapter glued to it and I'd like to replace it. I've searched Google but have not found anything. Heck, I'm not even sure what they are really called. A square of plastic about 4" X 4" that pops into the dash. Like where the extra 12vdc power connection is.
I second that. Often times, each individual panel or plastic piece has a ford part number stamped or molded in the back of it. If no numbers, then I would just go to the dealer and bring the piece and they can most likely pinpoint it after some research on a computer picture.
