Is it possible???
Old Jun 16, 2009 | 11:42 AM
04XLTRUNNER's Avatar
04XLTRUNNER
Is it possible???
to run 2" level kit with 35x12.50's on the FACTORY 20" FX4 rims, without causing any major rubbing
Old Jun 16, 2009 | 03:23 PM
broncobran68's Avatar
broncobran68
Probably. I'd be more inclined to say yes if it was a 2.5"
Old Jun 16, 2009 | 03:27 PM
04XLTRUNNER
yeah, but i found the 2" daystar for 120 bucks so i went with that one. i had a 2" on my 05 and i was able to clear 33x12.50s. the 09s have a little more clearance than my 05 did so i was thinkin i could run 35s. it will probably only run the lower plastic valence. if thats it then ill just trim that up a little.
Old Jun 16, 2009 | 03:54 PM
broncobran68
I only rub in reverse and it is very minor. If I dropped down .5" I am not sure it would make a difference. Go down to the tire shop and have it test fitted.
Old Jun 17, 2009 | 01:09 PM
04XLTRUNNER
thats how it was on my 05 before i did the level kit. my 33's rubbed in reverse at full lock. after the kit it was fine. so with the extra clearance the 35's on my 09 should act the same as my 33's on my 05. ill give it a shot. thanks
