Sponsored by: Real Truck
2008 F250 Re-Geared
Old Jun 15, 2009 | 09:44 PM
samurai's Avatar
samurai
2008 F250 Re-Geared
Picked up my truck yesterday from Ford. Regeared from 3.73 to 4.30 and overall am very HAPPY. While it is not "night and day", I definitely can feel some more "torque" on my drive wheels and am especially exzcited to hook up the big trailer in about a month.
I currently am running a 6" lift with 37" mud tires and although the 6.4 is plenty strong, I felt as if the drivetrain was "struggl;ing" just a bit to move a my truck.
Overall I paid more than I probably should have for both axles (4wd) to be done, but am 100% satisfied that Ford did it and will warranty it.
My ONLY concern that I have had for about 3 months before and after the gear swap is an intermittent cluncking in the drivetrain that the Ford Tech says is a miscommunication with the TCM and PCM. Anybody heard of this or experienced this? He said next time it happens and throws a code he will replace my TCM.
Any thoughts??
Old Jun 15, 2009 | 11:05 PM
ReAX's Avatar
ReAX
I would think your transmission will be happier with the change. I think your final drive is still lower than the 3.73 with the stock tires, but I haven't done the math to confirm. TCM/PCM sounds like the kind of thing I would have told someone to buy time to figure out the problem or suggest a programmer.
The PCM should do all power train, I would have said ECM (engine) and TCM (transmission). It's likely that the PCM needs to know the gear ratio and tire size to adjust the shifting, I remember this being a big issue with some other PCMs, not so sure about EEC-V or the computer based I've heard ford wanted to use.
Old Jun 16, 2009 | 08:04 AM
samurai's Avatar
samurai
Any thoughts on a "reputable" and "safe" programmer that will address my "PCM / TCM" issues? It is an intermitent problem that is STRESSING me out!!!!
I got the PERFECT looking truck in my opinion, just need it to be 100% reliable.
Old Jun 16, 2009 | 11:16 AM
redford's Avatar
redford
FTE Leadership Emeritus
Are you sure your slip joint just doesn't need greasing?
Old Jun 16, 2009 | 05:42 PM
suzuki0702's Avatar
suzuki0702
if u dont mind me asking im going to get the same swap. maybe 4.56 how much did they charge you?
Old Jun 16, 2009 | 06:31 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty
sweet looking truck, you need some Harley Davidson Smoked Headlights, that would top it all off.
when does it "clunk" when you shift from say park to drive and start to take off? could be a slip yoke problem?
Old Jun 17, 2009 | 06:11 AM
samurai's Avatar
samurai
The INTERMITTENT "cluncking" almost to the point that it wants to either stop the truck or sounds "like" it may shut off happened for example one day last week while I was on the interstate riding bout 60 mph. WHAT could it be???
Cost to regear from 3.73 to 4.30 was almost $3,000 which is a little steep and I will probably get flamed for it, BUT I am 100% confident in quality of parts, workmanship and warranty since Ford did it.
*Excited to hook trailer up in next few weeks and pull with new gears.
ps...........We are having a little baby girl TOMORROW!! Happy Father's Day on Sunday to me!!
Old Jun 17, 2009 | 06:12 AM
samurai's Avatar
samurai
Also just had ALL the Ford and F250 emblems on my truck painted Black and it looks SWEET!! Looking for Harley Head and Tail Lights at a decent price.
Old Jun 17, 2009 | 11:56 AM
Robs06SuperDuty
i'd take it to the dealer and maybe have them do a ride along. you can make your own smoked taillights. get some VHT Night Shades taillight paint. Not sure how much the 08 HD headlights are, i have HD's in my 06 if you havent seen my gallery.
congrats on the new arrival.
Old Jun 17, 2009 | 12:12 PM
senix's Avatar
senix
Classic example of a bad TCM. Mine had one at 600 miles. Started with a hard shift from 2nd to 3rd, felt like someone hit me from behind. Didn't do it 100% of the time but just about everyday.
Took it in, they reflashed the pcm..did not fix it. Finally was bad enough it threw the truck in limp mode.
Dealer didn't have one in stock for the 08's so he put an older one on and it worked, but eventually since it was not right it did what you are describing so we had to get the correct one on it.
That was the fix.
embry1123
Sep 20, 2020 09:02 AM
gorkah
Dec 18, 2013 07:15 PM
Joe_planet
6.7L Power Stroke Diesel
Dec 18, 2013 01:28 PM
samurai
Nov 6, 2008 12:54 PM
993/4ton
Modular V10 (6.8l)
Apr 30, 2007 06:40 PM
