body mounts needed!
Old Jun 15, 2009 | 08:33 PM
Hometown Pride's Avatar
Hometown Pride
body mounts needed!
I called every parts store around me and could only find the rear rubber for over a hundred dollars with no hardware. Someone told me to use hockey pucks. Any ideas on where to get complete set comparable with the original hardware.
Old Jun 15, 2009 | 08:43 PM
hp246's Avatar
hp246
Try National Parts Depot. THey have an online catalog, I believe they sell the urethane bushings.
Old Jun 15, 2009 | 09:20 PM
86bigred's Avatar
86bigred
N.P.D. or L.M.C. has them in their catalogs
Old Jun 15, 2009 | 09:23 PM
Hometown Pride
Has anyone ever done this type of work on their truck?
Old Jun 15, 2009 | 09:25 PM
hp246's Avatar
hp246
Yep. There are a few threads on this site regarding replacement of the bushings. What are your questions?
Old Jun 15, 2009 | 09:33 PM
Hometown Pride
Do I hust get a kit, rip out the old ones and intall the new ones, or is there more than meets the eye
Old Jun 15, 2009 | 09:41 PM
hp246's Avatar
hp246
First of all, why do you feel you need to replace the ones you have?
Usually they are replaced as part of sone form of restoration. You need to remove the old and replace the new, You are going to have to have some way of lifting the body, bed and radiator support in order to change them out.
Usually the bases are rusted so bad that it takes a torch or sawzall to remove them. If using a torch be careful around the gas tank. They are truly a PITA to remove.
The new hardware is pretty straightforward.
Old Jun 15, 2009 | 09:53 PM
Hometown Pride
Just trying to make the cab sit strait and true, cause the cab is almost hitting the box at the moment. I am going for a new truck restoration. I got to get some pics up, it is in really good shape besides the wear and tear parts. Im lookin at NPD now cant find em though. Slow computer as well.
Old Jun 15, 2009 | 09:59 PM
hp246's Avatar
hp246
They are in the online catalog for your year. You may still be able to get the Hardware through Ford. I bought it through them about 3 years ago. It took a patient parts counter guy though, cause the part part numbers have changed a cople of times over the years.
Old Jun 15, 2009 | 10:01 PM
Diesel_Brad's Avatar
Diesel_Brad
the rear cab mounts that sit on the crossmember tend to rot out the crossmember and fall thru it. You would have to replace the cross member or weld patches in to support the cab mount
LMC Truck Parts - Page 31
http://npd.dirxion.com/WebProject.as...Code=fod09flx#
Thats all the listings for body bushings in NDP, they only have a few steel retainers
Old Jun 15, 2009 | 10:19 PM
Hometown Pride
I dont know which to buy Polyurethane or lmc's rubber, Which is better, I dought anyone even has a set to look at around here.
could i buy either and use hardware from a bolt n nut store. Those $20 retainers look like they could be replaced with a washer, same with the shims.
Old Jun 15, 2009 | 10:25 PM
hp246's Avatar
hp246
That is a decision for you. The Polyurethane will wear better, but isn't "original" if you are doing a restoration. If you don't properly lubricate the polyurethane, they will squeak. The rubber is quieter, original, but will wear faster than the polyurethane.
I used the polyurethane and am happy with them for my purposes.
As far as the hardware is concerned, you probably can fabricate something. I used hardware from FOMOCO. I found it was cheaper from them than from any of the aftermarket suppliers. At that time, probably cheaper than buying all the hardware.
Old Jun 15, 2009 | 11:02 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I bought a complete urethane kit that I have yet to install (hardware & frame mount issues) and am now debating if it was the right choice.
It is my understanding they transfer more noise, they are stiffer, so it makes sense.
And as stated they have a tendency to squeak.
I already got em, I'll be using em!
-Enjoy
fh : )_~
Old Jun 16, 2009 | 09:23 AM
Diesel_Brad
I put a poly body bushing set in my 83 when i did the body lift. I hatted it. All it did was squeak and clunk. I took the poly ones out and put in OEM rubber ones and made all the difference in the world!!!
Old Jun 16, 2009 | 08:30 PM
Hometown Pride
Deisel Brad, Did you get them OEM rubber ones from the dealer or lmc? I am not big on plastic either, unless there is no other choice.
