5-Speed Questions...
Old Feb 17, 2002 | 02:25 PM
Greywolf's Avatar
Greywolf
I just bagged this unit for a hundred fifty bucks, including clutch, flywheel, and the original shaft so that I can swap the yoke if I have to. It's a Borg-Warner out of a 'Stang.
http://www.clubfte.com/users/greywolf/5speed.jpg
Trouble is, it's intended to have a cable operated clutch, and I want to adapt it to the old tried & true mechanical linkage.
At this point I'm not real sure exactly what gearbox it is - here's a close up of the tag that was on it:
http://www.clubfte.com/users/greywolf/trannytag.jpg
(The first four numbers/letters are: "E6ZR"
Any ideas and suggestions (other than wingin' it over the back fence) would be much appreciated. It's going into an '82 F-100 with a fresh 302.
Old Feb 17, 2002 | 05:49 PM
FortyFords's Avatar
FortyFords
This is 1986 1/2 (mustang,capri)T5 WC.it was orignally behind a V8
how many miles on it? this will determine if it needs rebuilt.
Any thing over 50,0000 watch out for.
common problems: front input ext housing gets worn where throwout bearing rides. there was an ec to change housing to steel instead of allum.
front input bearing /wears because people don't replace pilot bearing when changing clutch
Also rear output shaft seals leak.
also chk the front yoke on your dr shaft for wear if excessive wear put new yoke and rear bushing in trans.
Not a bad price if its useable
good luck
Rich
Ford Trucks Built Tough!
not with rocks
Watch out Mr Mayor of Truckville
Old Feb 17, 2002 | 07:49 PM
FortyFords's Avatar
FortyFords
Sorry I missed the other part of your ? the first time .
Yes this has a cable operated clutch ,changing to mech could be tricky
Hyd might be eaiser ,not sure! never done it though.
If you don't use this, I'd be interested in it
Rich
not with rocks
Old Feb 18, 2002 | 07:07 PM
FortyFords's Avatar
FortyFords
Some more info on this tranny!
Ratios
1st 3.35
2nd 1.93
3rd 1.29
4th 1.00
5th 0.68
input shaft length 7.18
pilot bearing size .668
Rich
not with rocks
Old Feb 19, 2002 | 08:00 AM
Cope's Avatar
Cope
Racerguy
1997 - 2003 F150
214
Jun 10, 2025 07:58 AM
Ratsmoker
19
Jun 6, 2004 10:32 PM
ivanribic
Offroad & 4x4
Feb 22, 2004 10:05 PM
Mil1ion
Jun 27, 2003 04:35 AM
Mil1ion
Alberta Chapter
Jul 22, 2002 01:29 PM
