Cold/Heat Control
How I have purchased a 2005 F250 and the cold/heat control doesn't work when in the MAX A/C. So therefore I have the coldest air always pumping out in the MAX A/C position with no way of adding heat in that position.
The manual says this is how it works. I want to know if there is any way of bypassing the override for the cold/heat control when in the MAX A/C position?
Thanks
Dave
