Knock sensor??
Old Jun 15, 2009 | 10:59 AM
Supercab's Avatar
Supercab
Wink Knock sensor??
We have a 1994 F150 with the 5.0 with mass air-(one of the first as I understand that 1994 was the change-over year) anyway: down the road a little we will need to replace the engine-(has about 160k now and runs great!) we have a nice low mileage 5.0 from a 1987 Cougar that we'd like to install in the truck.....only problem is that the '87 5.0 does not have the provision for the knock sensor in the block--can we still use this engine? any way to drill & tap the block for the sensor? can it be bypassed? Thanks!
Old Jun 15, 2009 | 11:13 AM
Conanski's Avatar
Conanski
You could drill and tap the block but it's no big deal if you just forget it and leave the connector hanging, should not set the CE light or affect engine operation.
Old Jun 15, 2009 | 06:28 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm
It will not trip the CE light however after a while it will get harder and harder to start. The computer will keep adjusting the timing looking for the knock. This is what I was told as the knock sensor went bad in my 88 F150 years back. It got harder to start every week. When I talked to the wench at my local dealer He told me that about the timing. I replaced mine and truck was back to normal in a couple days of driving.
Old Jun 16, 2009 | 06:31 AM
Supercab's Avatar
Supercab
Wink
So, It doesn't look like its the best thing to do if the computer will make the engine harder and harder to start-I wonder if it will evedentally not start at all? is there any way to electrically bypass the knock sensor?-just loop the wires at the plug may be?
Old Jun 16, 2009 | 06:25 PM
EPNCSU2006's Avatar
EPNCSU2006
I would not loop the wires. The knock sensor works very similarly to a normal audio microphone and generates a small voltage. I don't know exactly how the circuit is completed on the circuit board inside the computer, but I wouldn't take the risk of messing up something.
While you have the engine out of the car, why not go ahead and drill and tap the rear of the block for the knock sensor and install one in the replacement engine?
ModifierMR
38
May 2, 2024 11:52 PM
p.ward7885
WTB - Parts & other
Oct 22, 2015 02:32 PM
p.ward7885
1978 - 1996 Big Bronco
Oct 14, 2015 11:32 AM
bartlettf150
May 22, 2015 09:10 AM
rice975.0
Jan 27, 2011 03:32 AM
