valley pan cleaning?
Old Jun 14, 2009 | 11:22 PM
murrhee's Avatar
murrhee
hello, the motor and valley pan is real greasy and dirty on this 97 and is it ok to sray some engine degreser on and hose it off when shes cold? or will this be done some other way with all this computer stuff every where. thanks for any help, i just put a new k&n filter in and it sounds way better i think the old filter was way clogged up.
Old Jun 14, 2009 | 11:25 PM
pjwoolw's Avatar
pjwoolw
I used Simple Green. Mostly because I had allot of it. Just be careful and you ought to be OK. It will take more than one cleaning. At least that was the case with mine.
Old Jun 14, 2009 | 11:38 PM
kawa's Avatar
kawa
Simple Green is good, Brake cleaner works also, Just don't use PRESSURE, It's OK if the engine is warm to the touch but NOT HOT. You'll be OK.
Rog
ps:
Be prepared to find all kinds of goodies, tools, parts. nests, etc
Old Jun 14, 2009 | 11:41 PM
Talyn's Avatar
Talyn
cool, i need to clean mine, the diesel fuel i spilled in there today should do a good job of the oil.
Old Jun 15, 2009 | 09:26 AM
murrhee's Avatar
murrhee
cleaning
thanks, i will start the cleaning.
