What have you all done to upgrade your interior? Seatcovers, gun racks, seats.....so on. and how do you have your CB setup? Im looking particularly for twin whip setups.
I would normally be on the argument of fancy shmancy for the interior but this truck is my tow rig and My jeep is the beater not the truck.
Any pics you could supply would be greatly appreciated.
I was told a long time ago that twin whips aren't as good as a single. First you split the transmission then cancel each other out. Most of the antennas power is on the end and it transmits in a circle away from the antenna horizontally if you will. If you have an antenna on both sides of the truck as the "sound waves" collide it cancels each other out, if you catch my meaning. Your really better off with one in the middle on a flat plain, like the roof, it promotes the signal better. The guy I head this from is REALLY into these you should really see his f150. It looks like a beater because all his money went into the cb. For instance he has a ,get this, 2,000 amp generator running it. I saw it, it's HUGE! It looks like an alternator but it's gotta be at least 10" in diameter. All through one (really tall) antenna.
Twins make for a stronger signal fore-aft of the vehicle, which works nice on the freeway where most people you talk to are either before you or behind you, hence why the twin-antenna setup is preferred by truckers. Also, with twins you need to have them properly spaced away from one another, easy to do on a big rig but with a pickup truck you pretty much only have the mirrors as a suitable location (even better if they are towing mirrors). With a wheeling truck, or one that spends most of the time on back roads, the people you talk to can be virtually in any direction from you, so a big single antenna is probably a more suitable setup.
sorry for the hijack, but could you have one that works and one just for looks? i love that twin whip but i want it to work good too....
thats how mine is. i have the cb hooked up to one whip and im trying to get the scanner hooked up to the other.
my cb is zip tied to the ashtray on my 95. it works good and looks pretty good as well. i took the clip for the mic and tucked it between the headliner and the trim in the middle of the windshield. i will try to get pics of it later.
I'll try and get you a couple pics of my setup. I made my own bracket to hang my CB underneath the ash tray, not attached to it but in the area underneath it. I also run dual whips with them both hooked up on either side of my toolbox, they are 4 foot firestick 2's with tuneable tips. A friend of mine has the same setup and we can reach 8-10 miles with the squelch turned all the way down and probably 5 miles with squelch turned up so you don't have to listen to all the noise. Of course I live in Kansas so it is flatter here than most places and that helps.
Dual whips do look better and if properly set up and tuned can reach comparatively as far as a single antenna.
