AT shift arm snappage
Old Feb 17, 2002 | 06:07 PM
redneckdieselmechanic's Avatar
Old Feb 20, 2002 | 04:29 PM
lisavl's Avatar
lisavl
have a '92 F-150 Supercab, 2WD, auto/power, new starter, transmission, brakes, tires...iow, I thought I had replaced ebverything important that could fail(and did) within the last year.
Surprise!!
Yesterday, after driving about 25 minutes, I had to back up to get out of a parking lot. When I shifted into reverse, the shift arm went limp. As it turned out, I could still maneuver it into what were probably neutral and drive or overdrive or 1st gear (I could go forward and stop and rev the engine without moving. The display panel was meaningless at this point).
Anyone got a diagram of this mechanism? I'm hoping something just slipped and can be put back in place with relative ease. I took off the dash panel in front of it but didn't see anything that looked out of place and I'd like to know what's in there before I go any further. One thing I did notice was a cable coming from the malfunctioning mechanism that seemed too thin to be doing the job it was supposed to do. It was as fine as fishing line, but appeared to be tight and in place.
Excuse the lay terms; obviously I'm not a mechanic. Nor, unfortunately, can I afford to pay one at this time. So I'm it. Any feedback would be appreciated.
Thanks.
Lisa
Old Feb 21, 2002 | 01:29 AM
the law's Avatar
the law
I'm no expert, but try following the cable down from the steering column to the trannie. It may come off the column right up front or it may come off down at the bottom, I really don't know. Anyway, see if the connection to the switch on the trannie itself is loose. Maybe you just need to replace the cable.
Good Luck.
The Law
