new flywheel
Old Jun 13, 2009 | 10:51 PM
juchertf100's Avatar
juchertf100
new flywheel
im putting in a new flywheel presure plate disc exc, . is there anything i need to do to the new flywheel rough up or anything.
thanx juchertf100
Old Jun 14, 2009 | 05:59 AM
79superduty's Avatar
79superduty
if its new its ok.......
Old Jun 14, 2009 | 08:51 AM
Supercab's Avatar
Supercab
Wink
If its brand new out of the box the surface shouls be fine, sometimes there is a coating of some type on them to prevent surface rust when on the shelf in the box, this can be removed with lacquer thinner or mineral spirits, THEN after its installed and torqued to specs wipe it down with rubbing alcohol a couple of times before installing the clutch setup, do not touch the flywheel surface with your hands after wiping with alcohol as you install your clutch.
