the engine is readyyy! :)
Old Jun 13, 2009 | 03:47 PM
DJdemon6696's Avatar
DJdemon6696
engine got back from the shop
engine specs
1996 5.0 Reman Explorer engine (306) yes its 0.30 over
GT40heads
eddie air performer gap intake
holley 650Dp
comp cams custom cam
Intake Duration at 050 inch Lift 218
Exhaust Duration at 050 inch Lift 224
Duration at 050 inch Lift 218 int./224 exh.
Advertised Intake Duration 270
Advertised Exhaust Duration 276
Advertised Duration 270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.512 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.512 in.
Valve Lift with Factory Rocker Arm Ratio 0.513 int./0.513 exh. lift
Lobe Separation (degrees) 110
its going into an 1989F150 with a 5speed manual
what kind of rear wheel Hp can i expect?
i think between the range of 250-275 hp??
[URL=http://s198.photobucket.com/albums/aa217/demon6696/?action=view&current=105e3994.pbw]
can someone explain how the heck does those valve covers works? i dont see any breather hole or nothing.. just and oil filler hole
