A quick question about interior insulation????
Old Jun 13, 2009 | 11:01 AM
mechmagcn's Avatar
mechmagcn
Getting ready to insulate the interior of my 53 before the A/C installation.
For those who have used Dyna-Mat or the cheaper version of it that Mid-Fifty sells,(this is the one I bought) how well does it stick to the interior paint? Should the surface be glossy or sanded? I used the cheaper stuff in the interior of my Mack, which is just primed, and it didn't seem to stick real well.
I plan to line the whole interior with sound deadener and then add a layer of insulation on the roof, firewall and floor. Does this sound like a good idea?
Thanks for any advice, Jeff
Old Jun 13, 2009 | 01:03 PM
sdetweil's Avatar
sdetweil
Sound deadener first, then insulation, then jute, then carpet/whatever.
I used heavy duty RattleTrap, 80mil, like this from EBAY
100^ 80 Mil Rattle Trap FatMat Deadener+ Dynamat Roller:eBay Motors (item 370212660752 end time Jun-17-09 20:15:16 PDT)
and it stuck to everything.
I used this heat insulation on top
Automotive Heat Sound Insulation Auto Car Boat RV Quiet:eBay Motors (item 230344277831 end time Jun-19-09 08:07:50 PDT)
Sam
Old Jun 13, 2009 | 01:30 PM
havi's Avatar
havi
I'll have the Roast Duck
Maybe some rattle can adhesive will help?
Old Jun 13, 2009 | 11:01 PM
Huntfamily53's Avatar
Huntfamily53
Sam
Good links...
So, you still need to put heat insulation on top of the deadener? I did not know that. I thought the dynamat stuff did both? Good to know.
Old Jun 15, 2009 | 11:57 PM
t900enforcer's Avatar
t900enforcer
I used B-Quiet (did a Google search for Dynamat and found B-Quiet) sound deadener which stuck to anything and everything I out it on. Over that I put 3/8" insulation with rattle can adhesive. To make a long story short I found out that you should use the 3M high bond strength adhesive. Expensive but worth doing it only once. Results were great.
T900
Old Jun 16, 2009 | 05:36 AM
sdetweil's Avatar
sdetweil
Originally Posted by Huntfamily53
Good links...
Yes, the deadener does some limited amount of heat insulation, but its primary job is to stop vibration harmonics. it is not enough of a heat barrier for comfort.
Sam
Old Jun 16, 2009 | 07:02 AM
49willard's Avatar
49willard
Sam,
Did you do all surfaces the same way? i.e. doors and floor included?
Old Jun 16, 2009 | 08:05 AM
sdetweil's Avatar
sdetweil
Originally Posted by 49willard
Sam,
the doors only have the deadener.. the insulation would hold water no mater what you do..
Sam
