cooling issues
Old Jun 12, 2009 | 08:24 PM
jmmartin's Avatar
jmmartin
cooling issues
215-235ish with the kubota in tow, 215 for 2-3 hours running empty then suddenly 230ish... cause for concern or is the 230 within limits...
Old Jun 12, 2009 | 11:30 PM
dakotajeep's Avatar
dakotajeep
Mine runs hot as crap if I run the A/C. Otherewise it just runs hot. I really need to get a mechanical guage but for now its in the NORMAL range about the R to A range......
Old Jun 13, 2009 | 09:12 AM
jmmartin's Avatar
jmmartin
on mine the N-O area is about 215 Edge of the R is 230 a is 260, i dont know how accurate the factory is supposed to be but thats what mine shows
Old Jun 13, 2009 | 10:44 AM
PLC7.3's Avatar
PLC7.3
Diesel engine coolant temperature at the top of the radiator where hose attaches after high rpm or under load condition for 20 minutes should be (195-237*F) 91-114*C nice time to have a temperature reading point and shoot tool.
Try cleaning the rad exterior... pay special attention to the area between the a/c condenser and coolant rad..... use air first to clean debris then water.
Old Jun 13, 2009 | 10:46 AM
starmilt's Avatar
starmilt
This seems warm to me if I remember my fan kicks in at 205 or a little more and she starts cooling down to about 200 when under a hard pull, empty stays around 190 all the time. What rpms are you running when pulling.
Old Jun 13, 2009 | 04:40 PM
rupejosh's Avatar
rupejosh
mine runs on the o on normal typically but pretty much runs like dakotajeep explained how his runs.a little warmer with the a/c.if you do little stuff like flush the radiator change the cap etc. it might help as well
Old Jun 13, 2009 | 11:33 PM
jmmartin's Avatar
jmmartin
completly flushed the radiator and put the correct thermostat in about 2-3 months ago, i cant tell you about the fan because of how noisey the truck is to begin with. there are times when you take off and it is super loud comming from the front of the truck and then you may go days w/o hearing the roaring noise. the noise changes with speed and not with motor speed. and put a new cap on yesterday, b4 i made the trip
Old Jun 14, 2009 | 12:07 AM
starmilt's Avatar
starmilt
The roar of the fan is very noticable when it locks up should come on by temp not speed, at highway speeds when it comes on it is very noticable even with these noisy trucks.
Old Jun 14, 2009 | 08:25 AM
dakotajeep's Avatar
dakotajeep
Thats weird because I have never noticed my fan ever. Maybe I dont have a calibrated ear. I need to ride in one of your trucks to hear it and see if mine does the same.....
Anyone close to Manhattan, KS?
THad
Old Jun 14, 2009 | 08:35 AM
jmmartin's Avatar
jmmartin
am starting to think that while a buddy of mine is working at a ford dealership, i might need to replace a few parts. he looked up the cdr and said it was 40 for him to get it and nearly 70 for me 2. i think i may give them a lil business...
Old Jun 14, 2009 | 09:01 AM
chopper_53e's Avatar
chopper_53e
230* is about the max temp you want to run, and not for very long. Regular motor oil starts to break down at around 250*(Synthetic is around 400 I think). Typically your engine should run around 200, give or take a little either way. Most likely causes for running hot that I've seen are blockage in the radiator, bad fan clutch, and worn water pump impeller. To check the fan clutch, drive it around til it's up to temp. Right after you shut the engine off, while it's still hot, try to spin the fan by hand. If it spins freely the clutch is bad. If it doesn't move then it's locked and working fine, and your water pump may be bad.
Old Jun 14, 2009 | 09:07 AM
op diesel's Avatar
op diesel
I'd bet on the radiator. I had a similar problem with my 93 7.3 idi and the radiator was clogged.
Old Jun 14, 2009 | 10:41 AM
jmmartin's Avatar
jmmartin
true, everything on this truck has been 1987 original. and all are slowly failing. i know the water pump is circulating by watching the water flow through the radiator when up to temp.
Old Jun 14, 2009 | 11:05 AM
starmilt's Avatar
starmilt
THad
You don't need any trained ear here just one that works even barely when the fan comes on it sounds like an airplane taking off.
Old Jun 14, 2009 | 12:24 PM
jmmartin's Avatar
jmmartin
kinda like what the fan clutch in a Mack or such sounds like?
