Automatic trans to manual
Old Feb 23, 2002 | 10:01 AM
fordtrck302's Avatar
fordtrck302
OK right now I have a 1991 f-150 4x4 with a 302 and I have the E40D, I also have a 1984 Bronco with 300 that is manual im not sure what that tranny is called but would it be possible to swap the transmission so I can make my f-150 manual, if so how do I do it, cause I have all the spare parts I need to do it in my bronco but I just dont know if eveything will work, or if that bronco transmission will fit in place of my transmission now,, any help would be great thanx
1991 f-150 4x4 302
hooker headers, straght pipes
33 goodrich mudders
3" body
stock 3.55 gears
260-280 hp and 380-410 ft lbs of torque
all from crane camx powermax cam and lifters kit, bmk throttle body throttle body spcaer, crane cam rockers, more to come......
FORD BEATS THE BOW TIE EVERYTIME
Old Feb 23, 2002 | 10:06 AM
fordtrck302
the transmission on the bronco is a 4 speed if that helps any
Old Feb 25, 2002 | 07:26 PM
90Bronc's Avatar
90Bronc
I know that a lot of transmissions that Ford used were interchagneable between the 300/302/351s but I dont know about that particular transmission. What I do know is that it will most likely require new driveshafts unless you plan on using the ones out of the bronco (as long as the bronco and f-250 both have the same 9in or 8.8 rearends). I have also been told that without the electronic inputs to the computer from the transmission, the engine will not run. So you will need a new computer for a manual trans ($250 from local ford dealer, also said that will increase fuel mileage due to improvements made in computer). Then you may have to modify the tranny support crossmember. I have never done that particular swap but I have a 90 Bronco with a 351 and have researched a swap to a zf s542 trans and a np435. If you have driveshafts, the clutch, the new computer, tranny support crossmemeber, and oh yeah, make sure that the transfer case will bolt up to the manual trans unless you plan to swap the t-case as well which may require modifying the linkage if the bronco t-case is not a borg warner 1356 which is what your f-250 has. With all of the those parts it should work at least that's all that I can think of right now. It sounds like a difficult process so good luck.
Old Mar 5, 2002 | 09:37 PM
shazam's Avatar
shazam
I went for a auto to a stick in my 78 F150 4X4 all I needed was the peddles and a flywheel. the mount from the auto tranny worked I just had to turn it around to get the holes to line up.
Old Mar 5, 2002 | 10:44 PM
Leonard Bode's Avatar
Leonard Bode
