Window Crank/Door handle
Old Jun 11, 2009 | 08:25 PM
4thgenford's Avatar
4thgenford
Question Window Crank/Door handle
I've tried the search feature to find threads on htis subject, but can't make it work probably just me anyway I'm looking for the pinsthat hold the window crank and door handle on my 50 f1. Can anyone tell me where I purchase these. I have been told that they are just a hair biger than an 1/8th inch. Any helpwill be appreciated
Mike
Old Jun 11, 2009 | 10:10 PM
MO51's Avatar
MO51
I don't have any spares, but if it were me, I'd use my little box of drills, and insert them until I found a snug fit in the crank hole...and go in search of some wire that drill size. Or, buy a couple cheap drills that size, and snap'em off, use the smooth size for your job.
Old Jun 12, 2009 | 09:28 AM
4thgenford's Avatar
4thgenford
Thanks Mo I'll give that a try.
Old Jun 12, 2009 | 09:55 AM
Julies Cool F1's Avatar
Julies Cool F1
Or, try cutting a finishing nail of the right diameter. As I recall, a 2" (can't remember the penny size) seemed to be close. If you tap one end a couple times with a ball peen hammer, it will mushroom it enough to keep it from vibrating out as well.
Old Jun 12, 2009 | 10:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
72827S .. Inside Door & Window Handle Straight Pin / 1/8" x 5/8"
Fits: 1948/52 cars/trucks / 1948/56 panel truck's rear door inside handle.
Old Jun 12, 2009 | 10:45 AM
4thgenford's Avatar
4thgenford
Thanks again. Thats why I come to you guy's and gal for these questions, you make so easy.
