1978 - 1996 Big Bronco
1989 Bronco buildup
Old Jun 11, 2009 | 07:23 PM
Kheitain's Avatar
Kheitain
1989 Bronco buildup
I've got a 1989/90 Bronco and a 1989 F-350 Crew Cab 4x4 and I am intending to swap the axles across. I was wondering if anyone could give me some tips before I start pulling the axles off.
Old Jun 12, 2009 | 02:25 AM
greystreak92's Avatar
greystreak92
First off, welcome to FTE and the Big Bronco Forum. We will endeavor to get you the most accurate info we can muster.
Some things to consider:
Solid front axle to replace a TTB axle
- leaf springs on the F-350
- coils on the Bronco
- solid axle under the F-350
- Twin Traction Beam D44 under the Bronco
Driveshaft(s)
- yoke/flange changes
- lengths
Springs
- no leaf spring provision under the Bronco
- No coil spring provision on the F-350 axle
I'm sure its been done. These are just the things that you will face immediately.
Old Jun 12, 2009 | 12:37 PM
Kemicalburns's Avatar
Kemicalburns
if you wish to stay coils which i suggest you do contact Cage Offroad. they have everything you need to make this happen and do it right. the rear diff will bolt right in and should require 0 modifications. the driveshafts may require different ujoints/flanges to bolt up properly but otherwise thats it.
Old Jun 12, 2009 | 11:26 PM
Kheitain's Avatar
Kheitain
Thanks for the quick replies. I was hoping to keep the coil springs and modify the front axle to match up. I was not aware that the rear would bolt right in!
Old Jun 13, 2009 | 12:06 AM
Kheitain's Avatar
Kheitain
The u-joints won't be the issue as I'm dropping the 460 (on propane) and the tranny into the bronco too. I'm aiming to stuff 42's under it so I'm mainly worried about the coils and the u-joint angles.
ps. sorry about the short replies I'm on the road alot.
Old Jun 15, 2009 | 11:28 AM
Kemicalburns
well definatly check out Cage offroad then. they have exactly what you need to make this happen
preston32
Dec 5, 2012 04:24 PM
Big block bronco
Jun 18, 2010 03:06 PM
HaveSomeFanta
Bronco II
Feb 13, 2004 06:54 AM
TheBlackRhombus
Jun 30, 2003 09:42 PM
