rear end break in
Got back and had them check it out. They replaced the gears again. This fall, it started making the whine again. I've read different places, about breaking in the rear end after a gear swap. Ford says they never have. Now, the main part of my quest. This is a tow rig, not a dailly driver. If the mechanics, change gears in a local truck
that is driven every day, those gears would(?) be automaticly broken in by the time they tow something. (at least more than my 1 mile home). I'm starting to think that I need to go out and drive it solo for a few hundred (?) miles before I start towing. Is there any logic in what I'm thinking? Thanks, Elliott
Metro2
Drive for 20 to 30 minutes with no load, at normal speeds. Freeway speeds are ok. Then stop, let the diff cool down completely. Do this again 3 or 4 times. This helps remove the phosphate coating and cold work the contact surfaces without overheating the oil. Don't tow or accelerate hard for at least 500 miles.
When you do tow, don't pull hard (like up a long grade) for more than 10-20 minutes at a time until you get another 500 miles on the set. When you tow, the gear teeth flex and new material will be making contact, that's why you have to take it easy the first 500 when towing.
I've never had them tell me to change the diff oil, but I don't see any reason why it would hurt. If you did, at least you could visually check for problems. I've always broken my gear sets in this way, and never changed the oil after break in, and I've never had any problems.
