Manual Hub Service
NOTE: Any time the hub lock is removed, a new O-ring seal must be installed. Install a new O-ring.
CAUTION: The service replacement kit includes two O-ring seals. One for testing the hub lock assembly and one for reassembly into the wheel hub.
DO NOT REUSE O-RING SEALS. Install a new gasket and O-ring.
Rotate the hub lock dial to clockwise position (LOCK). Apply lubricant to the inner and outer splines.
Insert the hub lock into the wheel hub while slowly turning the wheel hub to align the splines. Lift/jiggle the axle U-joint while pushing the hub lock into the wheel hub.
There was reference to vacuum checks which I don't think applies to manual hubs. Just confused me. LOL I haven't looked at mine as yet so don't take this as an exact procedure. But the many hubs I've serviced on different vehicles of my own it's close. Also the test o-ring reference pobably doesn't apply.
Attachment 15678
There was reference to vacuum checks which I don't think applies to manual hubs. Just confused me. LOL I haven't looked at mine as yet so don't take this as an exact procedure. But the many hubs I've serviced on different vehicles of my own it's close. Also the test o-ring reference probably doesn't apply to MLH's.
