chip installation problems
Old Jun 10, 2009 | 11:18 PM
jleal_21's Avatar
jleal_21
i installed my diesel site chip today and didnt have the best outcome. 1st problem is that when i switch thru the positions the engine dies off sometimes; usually while setting it back to a lower hp setting? when the engine dies i doesnt always start back and i have to disconect the batteries and then start it back up. 2nd is that when i put it on high idle the wait to start light comes on(engine is running), is this normal?
last problem doesnt have to do with the chip; its just that my truck doesnt have to good of a throttle response and hoped the chip would help but its not so much. what happens is that when i get on the skinny pedal pretty hard for a take off she tries to take off but then looses power suddenly. truck keeps going just not strong enough, but if i ease on the pedal so she can get going and the punch it the truck runs strong. what could cause this? this happens with or without the chip.
Old Jun 10, 2009 | 11:21 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
did you clean the protective film off your pcm really good - unplug your map sensor and see if it makes a difference
Old Jun 10, 2009 | 11:27 PM
jleal_21's Avatar
jleal_21
where is the map sensor? i did my best cleaning the film off and it looked like all the contacts were clean.
Old Jun 10, 2009 | 11:47 PM
jimwilsonmasonry
look at your intake coming off your turbo and there will be a black hose running up to a little box unplug the electrical connection take it for a drive if it drives the same then your map sensor is shot and if its shot your truck wont hardly make any power
Old Jun 11, 2009 | 11:09 AM
jleal_21's Avatar
jleal_21
i unplugged the map sensor and it runs the same, only difference is that cel comes on when sensor is desconnected.
Old Jun 11, 2009 | 11:29 AM
kawa's Avatar
kawa
One other thing to check is what codes, if any are you throwing? Get a reading and then you will have a place to start.
Let us know what you find.
Rog
Old Jun 11, 2009 | 11:58 PM
jleal_21's Avatar
jleal_21
no codes are being register when the truck dies.
what does the map sensor do and how common is it that they go out? i ask cause i checked some prices and they
arent so cheap.
Old Jun 12, 2009 | 06:27 AM
Hussler's Avatar
Hussler
MAP sensor is OK then. If you unplug it and it runs much better then it could be a bad MAP or clogged hose. Problem is elsewhere so don't waste your money on a new MAP.
And it purpose is detecting boost. Its output to the PCM is a varying frequency. The higher the intake boost the higher the frequency. PCM uses this to determine fuel.delivery.
Old Jun 12, 2009 | 05:52 PM
jleal_21's Avatar
jleal_21
should i be able to roll some coal with this chip or will i need injectors?
Old Jun 12, 2009 | 07:40 PM
rideracelivemx7's Avatar
rideracelivemx7
well when i have my chip on extreme which is 140, i can throw a nice cloud at idol, on the road its an ok stream, i deff wouldnt say it rolls coal, sticks will roll coal but youd need a tranny in the next year after that hah
Old Jun 12, 2009 | 09:22 PM
jleal_21's Avatar
jleal_21
well i guess i'll have to settle for the cloud of smoke for now, but you now pms can only be held off for a little while. lol
Old Jun 13, 2009 | 01:08 AM
Oversize's Avatar
Oversize
Im not sure about the effects of the chip, but as for the power issue with the sluggy pedal have you checked your fuel filter and more specifically the FPR screen. If that screen is plugged up it will really mess w/ your power, and pedal response time. Have you checked your fuel pressure either. If thats too low the power will be real low. Might concider shimming your FPR if you havent already. You dont have a signature to tell us much about what youve got. Just throwing ideas out here.
Old Jul 4, 2009 | 10:05 PM
jleal_21's Avatar
jleal_21
i went to the junk yard yesterday and bought me a used map sensor for 10 bucks and put it on the truck and it actually did help. i'm thinking that the sensor was messed up and would bog the truck down. truck takes off really good now and the turbo spools up alot better. thanks for the help guys.
