Fuel pressure question
Old Jun 10, 2009 | 11:34 AM
ford390fe's Avatar
ford390fe
I've seen it somewhere in one of the threads regarding fuel pressure. Can you adjust it on the stock lift pump? And if so how much pressure is ok to go up to ? Can there be an increase in overall power and throttle response from increasing the fuel pressure? If possible can someone tell me how to adjust it on the lift pump? Thanks guys.
Aaron
1975 F-250 390FE eddybrock performer package, headers, 35s
1994 F-250 turbo diesel idi, reg. cab, 5 speed, boost, pyro gauges, 4 inch stacks
Old Jun 10, 2009 | 12:19 PM
Lazy K's Avatar
Lazy K
No you can`t adjust the stock lift pump. From what I`ve read here it would be a bad idea anyway as the injector pump would not like it.
Old Jun 10, 2009 | 06:29 PM
starmilt's Avatar
starmilt
There is nothing on the lift pump to adjust, these only need 4 pounds pressure and at that they are returning part of the fuel.
Old Jun 10, 2009 | 07:03 PM
GenLightening's Avatar
GenLightening
Stock is around 7psi @ max RPM and the IP can only take up to about 9 or 10psi before damage occures to the seals. Some have said they noticed a slight increase in power after switching to an electric lift pump, but they may have had a very worn lift pump before.
Old Jun 10, 2009 | 08:08 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Running higher fuel pressure into the injection pump changes the timing.
Higher pressure = advanced timing
Any power gain seen is probably from the advanced injection timing unless the stock lift pump was weak with either fuel amount delivery or pressure.
