Sponsored by: Auxito
Replacement Lenses
Old Jun 9, 2009 | 02:00 PM
SnowHiker's Avatar
SnowHiker
Replacement Lenses
I was thinking of putting new ones in.. they are ten years old and lookin a little yellow. have any of u done this? if so, how is it done, including the "aiming" of the lenses ., thanks
Old Jun 9, 2009 | 02:27 PM
KingRanchMan02's Avatar
KingRanchMan02
Changing the lens and or the headlight bulb, the headlight has to be removed. Under the hood, in the area just behind the headlight are two metal tabs. Pull up on these tabs to release the lens assembly. Then work it out. The adjustment for the lamp is in there too, just not accessible from outside the vehicle. Good luck!
Old Jun 9, 2009 | 05:39 PM
1Aauto's Avatar
1Aauto
Former Vendor
Not sure if you actually needed to buy new lights,but here's a link to our headlight section if you wanted to check them out.
Ford Truck Headlight Kits
Old Jun 9, 2009 | 07:52 PM
Aztrainer's Avatar
Aztrainer
It is easy to change them, but remember you will need to make sure they are pointed in the correct area and distance from your truck. They are easy to change as long as you take your time and line up all of the holes correctly.
Old Jun 10, 2009 | 07:01 PM
fordmerc's Avatar
fordmerc
Before making the decision on expensive headlights, try buffing them with chrome polish. It is cheap and easy, and you may be happy enough with them that you won't have to spend the money on new ones. I did this to mine, and it worked far better then the expensive headlight restoration kits.
