D44 or D50?
Old Jun 9, 2009 | 12:35 PM
bill11012's Avatar
bill11012
Modular motor junkie
D44 or D50?
how do I tell which front axle my parts truck has?
Did they put the D44 in the HD 3/4 ton diesels?
If I put this in my DRW F350 what do I do about the SRW hubs?
can I swap a HD f250 rear gear into a f350 DRW?
Old Jun 9, 2009 | 12:45 PM
Franklin2's Avatar
Franklin2
They did put Dana 44ttb's in the f250's with the diesels, standard equipment. The Hubs are much larger on a dana 50 ttb axle.
Just follow the other thread in this forum that you replied to awhile ago. That guy is doing the same thing, trying to convert a dual rear wheel truck to 4x4 and use the dual rear wheels up front also. They already said you have to have a dana 50 ttb or a dana 60 frontend to make it work.
Here's the other thread. https://www.ford-trucks.com/forums/8...front-hub.html
