squeak from the transmission?
Old Jun 9, 2009 | 11:10 AM
zak8tac's Avatar
zak8tac
So last week a new squeak started...It sounds exactly like a belt squealing, however it is coming from the front of the tranny, i hear it from the bellhousing. It does it with the clutch out, in any gear or neutral at low rpm's like 1000 or under, it goes away after I push in the clutch sometimes. On a side note I replaced the output shaft seal on the tranny and did a flush and put fresh oil in it (synthetic 75w-90) the squeak went away for a couple days but now its back, which makes me think its coming from possibly the input shaft bearing? What do you all think? NP435
Old Jun 9, 2009 | 11:12 AM
Recoil's Avatar
Recoil
Possible your throw out bearing?
Old Jun 9, 2009 | 11:21 AM
zak8tac's Avatar
zak8tac
I would think if it was my throw out bearing it would do it with the clutch pushed in though and not let out. And like I said after the fluid change it quit for a couple days, I don't know if that was just a conincedince(sp?) or not.
