Back and forth wheel
Old Jun 9, 2009 | 10:17 AM
randy450r's Avatar
randy450r
2001 F350 4X4 When i take a sharp turn then go strait the streering will go back and forth bad Replaced steering stabalaizer and all new tie rods.
Old Jun 9, 2009 | 10:21 AM
just another truck's Avatar
just another truck
Have you checked your ball joints, then next, I would go after wheel bearing assembly.. But dont run out yet.. there are eal pros signing in any second
Old Jun 9, 2009 | 10:25 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I agree with Pat. Jack your tire up off the ground, get a long pry bar and stick it under the tire. Try to lift it up and down, if you have any movement then you need to do this. click here
Old Jun 9, 2009 | 10:34 AM
Mike F250's Avatar
Mike F250
I try to follow any threads like this because the same thing happened to me. It used to happen only about once a week when I first got my truck. It has not happened for almost a year now. I guess the truck got over its illness?
Anyway, I have yet to see a definite answer to the problem. Most threads point towards the front end parts. U joints are a logical explanation. I don't recall who but someone said air in the PS/PB lines???
I didn't do anything to correct the issue because I couldn't find anything to correct. Also had the dealer inspect it. If they couldn't find a reason to take more of my money I guess I'm alright with that.
Old Jun 9, 2009 | 01:20 PM
patrick77598's Avatar
patrick77598
Im thinking I have the same problem, but boy does that ball joint replacement look
complex, I'm not sure im up to tackling that on my own yet. Is it as hard as it looks?
Old Jun 9, 2009 | 01:46 PM
caleb90's Avatar
caleb90
Temporarily Deactivated
sounds like you front hubs are locked and u have a bad u joint.all trucks in 4wheel drive will do it if u have your wheel cranked all the way
