idling trouble- please help
What motor? 302 or FE(390?) All stock? how many miles? Automatic transmission? What color smoke(blue, black, white?).
Do you have a tachometer to check rpm? Did you adjust the idle MIXTURE screws(in the front of carb)? First, bottom them out lightly, then turn them out 1 1/2 turns. Start truck and then slowly adjust them in till rpm just starts to fall off. Then back out 1/4 turn. Now adjust the idle. Idle has to be low enough for mixture screws to work, so make sure it's not over 700-800 rpm. Make sure the choke is properly adjusted also, make sure it's not falling closed, as this will make it stall also.
Fixing problems over the internet is kinda hard, but with some ideas you can at least do some checking. Hopefully you can get going in the right direction and get it fixed.
The idea is to set the idle mixture screws for highest vacuum(rpm), then adjust your idle to correct idle rpm. The mixture screws are kinda hard to get to on an Autolite, but they are under the front bowl. Like mentioned, start about 1 1/2 turns out from bottomed out(lightly) and then slowly rotate one at a time to reach max rpm(listen carefully to engine). Then reset your idle speed.
Gauges help, but if you are careful and listen you can get it close enough if it's that far outta whack.
Color? I was referring to the color of the SMOKE out of the tailpipe. That will determine what is wrong with it. Black is "too rich", blue is oil, white is steam(possible antifreeze leak-head gasket/intake gasket problem).
