Sponsored by: Real Truck
Your door is ajar light
Old Jun 8, 2009 | 06:05 PM
ponyboy123's Avatar
ponyboy123
Lately upon entering my 04 F350 the "door ajar" light stays on. Sometimes it goes off in a few seconds, other times it stays on for the duration of my trip. To answer the easy question, no the door is not open, hehe. Anyone else ever experience this type of problem or have any ideas on a remedy? As always, thanks for any and all suggestions.
Old Jun 8, 2009 | 06:09 PM
cparks's Avatar
cparks
I had that problem with my 2001 SuperDuty and my dad also on his Excursion. Inside the door mounted on the lock / latch mechanism is a little push button switch with a wire connector. On mine I had to replace it. On his we just took it off and found it was stuck. We cleaned and lubricated it and never had the problem again.
Old Jun 8, 2009 | 06:10 PM
Ballswedge's Avatar
Ballswedge
get some electronics cleaner from your local auto parts crib and spray the hell out of the door switches. This is a fairly common complaint among SD owners and is usually dirt buildup in the switch itself.
Old Jun 8, 2009 | 06:29 PM
ponyboy123's Avatar
ponyboy123
Cool, thanks for the info. Now if I can just get this front end rattle figured out the truck will be tip top once again.
Old Jun 8, 2009 | 06:35 PM
dew the thunder's Avatar
dew the thunder
WD40 works as well. Sprayed my truck's door latches probably 5 years ago and haven't had an issue yet.
Old Jun 8, 2009 | 06:40 PM
Ballswedge's Avatar
Ballswedge
Only problem with wd40 is that it attracts dust. If the OP lives in a dusty area, he could make the problem worse.
