03 f150 dyein
I agree with Fireball...the torque converter has a solenoid that locks it in for overdrive.This effectively directly connects the engine to the rear axle.If this solenoid is stuck,it will indeed do what you describe.Concerning how to fix it,I suspect that either the solenoid needs to be changed out,or the torque converter is internally damaged,and needs replacing.
