Mud run
Old Jun 7, 2009 | 09:23 PM
429PI IN 75 f-100's Avatar
429PI IN 75 f-100
Mud run
I am planning on mud running my truck this year for the first time and was wondering if any one had any tips. The truck is a F100 with a 429 in it, 4in lift posi lock in the back 4.11 gears also was wondering if any one knows of cheap way of locking the front diff also with out welding
Old Jun 7, 2009 | 09:36 PM
Holiver31's Avatar
Holiver31
A cheap way of locking without welding? Good luck lol You could try to find a used or rebuilt selectable locker.
Old Jun 7, 2009 | 09:46 PM
peganit2's Avatar
peganit2
Mini spools or full spool aren't that expensive. I think under $200 for the full spool and under $100 for the mini-spool . You will have to pay someone to set up the full spool if you can't do it yourself though. The mini-spool bolts in.
If you were thinking about the same effect as welding the spiders anyway, spools are a good bet.
Old Jun 7, 2009 | 11:22 PM
lunki98's Avatar
lunki98
what kind of mud running do you plan to do? If you lock front and rear you won't be able to turn. I run open differentials front and rear and usually do fine. Just my preference of course. The mud pit I race is a horse shoe shape. Spray WD-40 or boot silicone spray around the base of the carb and air cleaner as well as all over the distributor to keep moisture out. Here is a link to one of my runs. Luke bison mud bog - Bing Video
Old Jun 7, 2009 | 11:33 PM
peganit2's Avatar
peganit2
Sure he can, it just takes a whole lotta floorin'.
Old Jun 8, 2009 | 08:23 PM
429PI IN 75 f-100
The race is a straight style drag. Was thinking of taking a old set of tires and taking the hot knife to them for some deep lugs was wondering has any one else done this and how does everyone water proof their engine i was thinking of just tarping up the bottom of the engine
