Future Mud Truck
Old Jun 7, 2009 | 08:35 PM
Mothatrucka's Avatar
Mothatrucka
Future Mud Truck
I have an 89 350 and she is not starting. I just replaced the plugs and wires today and last month did the fuel pump and changed the fuel filter. I checked the high pressure fuel pump and that seemed to be working. I had it running rather well when I put one of the vacum hoses in a gas tank but I wouldnt stick the hose all the way in the gas just enough to inhale some fumes. Any suggestions on what this could be? Bad injectors? I also put some injector cleaner in the tank. The truck has sat for awhile. Another question does anyone know the firing order. I have looked online and found 13726548 and wondering if that is right
Old Jun 7, 2009 | 08:39 PM
Mothatrucka
If anyone wants to see pictures of it I just have to figure out how to upload them
Old Jun 7, 2009 | 08:41 PM
Dean88's Avatar
Dean88
What motor, 460 or 351W?
Old Jun 7, 2009 | 08:50 PM
Mothatrucka
the egine is 351W
Old Jun 7, 2009 | 09:39 PM
Dean88's Avatar
Dean88
Yupp, thats the right firing order.
To upload pics get a photobucket account and then upload your pics to there, then copy and paste the image code to here.
Old Jun 7, 2009 | 09:41 PM
Dean88's Avatar
Dean88
I would drain all of the gas out and refill with some fresh stuff. Next I would purge all of the lines and valves by pulling out the fuel filter and turning the key on to cycle the pumps a couple of times. Make sure that a good amount of gas comes out and that it is a good color.
Old Jun 7, 2009 | 10:25 PM
Mothatrucka
When i replaced the fuel filter last week i drained all the gas out and what not and I am getting clean gas on top of the engine where you can check the fuel pressure. I might try and see how much pressure I am getting. If that is the issue how could I go about correcting this?
Old Jun 7, 2009 | 10:36 PM
Dean88's Avatar
Dean88
Def check the pressure, I think autozone loans out the guage, it should read 40 psi idle and may fall down to 30 psi when WOT, if you don't have enough pressure, first try replacing the pressure regulator, its the small 2'' around cylinder thing on the driver side fuel rail. If that still doesn't fix it, then your probably looking at one of your low pressure pumps in your fuel tank is shot and your not getting enough fuel flow to your high pressure pump to keep up.
Old Jun 7, 2009 | 10:48 PM
Mothatrucka
Ok I just replaced the fuel pump in the tank, I replaced the entire fuel pump assembly piece in the tank and that was working when I put it in. I also tested the high pressure fuel pump and that seemed to be working as well. Is the pressure regulator before or after the high pressure fuel pump?
Old Jun 7, 2009 | 10:50 PM
Dean88's Avatar
Dean88
After, its on the fuel rail on the motor itself. Driver side I believe between the 3 and 4 injector
Old Jun 8, 2009 | 06:30 PM
Mothatrucka
Ok thanks I will keep you up to date on how everything goes. Do you know about how much the fuel pressure regulator costs?
Old Jun 15, 2009 | 06:31 PM
Mothatrucka
I ended up replacing the high pressure fuel pump and the truck fired right up. She is running like bran new now. Next step is to replace rotted out floor boards. Anyone have any suggestions? Ideas? I was thinking about taking the bench seat out and throwin in a pair of captain chairs just for the fun of it. I am also on the hunt for some type of lift, possibly just blocks and shocks.
Old Jun 15, 2009 | 06:57 PM
Mothatrucka
Some type of suspension lift that won't put to much of a whole in my pocket
bigdaddy coolbird
Oct 25, 2014 10:17 AM
zloetakoe
Sep 3, 2013 10:09 PM
RTennant71
16
Jun 13, 2011 10:06 AM
dynocompe
2004 - 2008 F150
Feb 5, 2010 09:03 PM
jfboy
Modular V10 (6.8l)
15
Apr 10, 2006 07:34 PM
