Sponsored by: Real Truck
Name That Driveline Problem!!
Old Jun 7, 2009 | 04:25 PM
UGA33's Avatar
UGA33
The truck is an 06 250 crew cab shortbed. I have what I would call a clunk in my driveline somewhere. It has been somewhat tiny for the last few thousand miles, but Friday it has become very evident. When you are coming to a stop, as soon as it comes to a complete stop I can feel a clunk. When you go to take off, as soon as you let your foot off the brake it will clunk, and as soon as you put your foot on the gas and take off it will clunk. It doesn't do it under any other driving conditions. There is no whining or howling from the rear end and there is plenty of fluid in it even though i have a weep from the pinion. I have checked all the u-joints and engine and tranny mounts so now I guess the read end internals are to blame. Anyone ever had this happen or have any idea what it could be?
Old Jun 7, 2009 | 05:02 PM
newgeek's Avatar
newgeek
dry drvieshaft splines, take er off and grease er up. just mark as you go so it goes in the same and balanced. good luck. you can search more details on here there is a good write up.
Old Jun 7, 2009 | 05:03 PM
high ho silver's Avatar
high ho silver
My first thought is, it may be time to grease the slip yoke...While your at it, put in a grease fitting so you won't have to remove the rubber boot next time to do the job.
Old Jun 7, 2009 | 05:33 PM
UGA33's Avatar
UGA33
I greased the slip yoke two months ago.
Old Jun 7, 2009 | 09:06 PM
EXv10's Avatar
EXv10
Get under there and shake the rear of the driveshaft up and down hard. There were 2 pinion yokes, 1 one was short and got loose on the splines. I would replace the pinion seal and tighten up the yoke first. It won't necessarily howl if your pinion is loose............smokin Obama, what's the US coming to.
Old Jun 7, 2009 | 11:23 PM
UGA33's Avatar
UGA33
Thanks for the advice. I will give that a try tomorrow.
Old Jun 8, 2009 | 12:01 AM
KelVarnson's Avatar
KelVarnson
Something I have done before that works pretty well for tracking down mysterious driveline clunks:
Put the truck in park, with the parking brake off. Get under the truck in and put one foot on one of the rear tires. If you push repeatedly, and time it just right, you can really get the truck rocking back and forth hard. Clunks due to driveline slack may become evident.
Old Jun 8, 2009 | 12:07 AM
UGA33's Avatar
UGA33
Will try anything at this point. If it does turn out to be rear end issues, thankfully, my aunt and uncle own and operate a junk yard with 05-07 SD's coming in all the time. Thanks for the tip
Old Jun 8, 2009 | 10:00 AM
EXv10's Avatar
EXv10
Great idea! I never quit learning. Rep point given.
Old Jun 8, 2009 | 10:20 AM
Smokeispower's Avatar
Smokeispower
Loose u bolts on the rear axle or even spring shackle bolts could do that too - you'd see some shiny bits if that was the case.
Old Jun 8, 2009 | 10:58 AM
KelVarnson's Avatar
KelVarnson
How cool is that for a family business?
Thanks for the reps! I should mention that I like to avoid laying directly in a tire path when I do this, in case it slips out of park
Old Jun 8, 2009 | 04:18 PM
Fordfanatic4life's Avatar
Fordfanatic4life
if u already did the spline lube scenario (which would have been my first guess aswell), then look for U-joint wear....
Old Jun 8, 2009 | 04:30 PM
Furian's Avatar
Furian
You Keep What You Kill
Ha! Death by Super Duty - Number 578! Well, at least the story will be air'd on Spike TV!
Old Jun 8, 2009 | 05:50 PM
69Boss521's Avatar
69Boss521
Is it an auto? If it is clunking as it is down shifting then it may be the TQ converter or your line pressure is off.
Old Jun 8, 2009 | 08:31 PM
UGA33's Avatar
UGA33
Don't laugh at my artwork using Microsoft Paint, but it gives you an idea of what my problem surely has to be. EXv10 and KelVarnson thanks for your methods of trying to figure this issue out. I went to take the driveshaft and shake it up and down and the thing would not budge. So I laid on my back and pushed the rear tire with my foot and no noises were being made. I watched the back axle and I was literally being able to simulate what a trucks rear end without ladder bars would look like trying to sled pull! The dang rear leaf springs looked like a fat woman's triceps as she is trying to wave down a cab! I had never noticed the bow in them, but I am pretty sure they are the culprit. Below is a world class artist's rendition of the springs.
