Ford Sync Question
Old Jun 7, 2009 | 03:45 PM
kwc27's Avatar
kwc27
Ford Sync Question
Wow, it has been awhile since I've been here.
I bought a new 2009 F150 on Friday (picts coming soon) and it has Microsoft Sync. I got it hooked up with my iPod and love the results.
My question has to do with if I start at the beginning of my playlist and keep listening to the songs then turn the pickup off. I turn the pickup back on and it will pick up where I left off on the song it was playing. However, when I press the next song button, it only goes to the next song by that particular artist and it will repeat the song if it is the only one by that artist. I can't make it go through the rest of the songs without saying "play all" but then it goes back to the first song on the iPod and I have to shuffle back through all the songs I've heard already to get back into place.
What command do I have to say to get it to play all songs from where I left off?
Hope this makes sense, thanks.
Old Jun 7, 2009 | 05:21 PM
silver05fx4's Avatar
silver05fx4
thats odd mine doesn't do that...it will pick it up right in the middle of a song and will skip to next song with out issue
but also i don't have a ipod i use a 30 dollar mp3 that the hole thing is small and has a flip out usb and hangs on the dash so i have no wires
Old Jun 7, 2009 | 08:02 PM
Aztrainer's Avatar
Aztrainer
I have not been here in a long time, but I am going to be getting an 09 this week and have a question about the Sync system. Could you put a flash drive with music and run it off of that?
Old Jun 7, 2009 | 08:29 PM
Bsimmer3000's Avatar
Bsimmer3000
You can add a hard drive, MP3 player or flash drive via the USB. There is also a USB2 mod here you can add an extra cable add hide a hard drive up somewhere.
Old Jun 8, 2009 | 12:28 AM
Jeremy2788's Avatar
Jeremy2788
Did you try saying the shuffle command? Then it should start playing different artists.
Old Jun 8, 2009 | 08:39 AM
FTrookie's Avatar
FTrookie
I tried using my flash drive and it did not recognize any media device. Is there a particular way you have to load the music to the flash or attach the device to the Sync?
Old Jun 8, 2009 | 09:14 AM
Bsimmer3000
You should just plug it in then select USB and you should be able to select the files you have in there. As long as the files show when it's plugged into a pc then they should play on your radio.
Bsimmer3000
Old Jun 8, 2009 | 01:00 PM
stevenailor's Avatar
stevenailor
I have noticed the same thing. I believe it will skip only to the album it was on when you turned off the truck. I will have to check it out to make sure.
Old Jun 8, 2009 | 07:12 PM
kwc27's Avatar
kwc27
It does work if I say shuffle, but then it plays songs at random and not in the order they are on the ipod. I just like to know the order of the songs so I know what's coming up. Maybe I just need to stop being picky.
Old Jun 8, 2009 | 07:56 PM
Aztrainer's Avatar
Aztrainer
Really, cool.... So since it has a USB2 could I hook up a external 80GB hard drive? That could/would be so cool.....
Old Jun 8, 2009 | 08:06 PM
gpp's Avatar
gpp
i think the problem may be in how the ipod is setup to play music in general.mine did the same thing but my grandson,who replaced my son,said he would fix it.he did,it works like it should so im a happy old man .no,i dont know what he did.
Old Jun 8, 2009 | 09:02 PM
Bsimmer3000
you sure can. i have a 320gb WD drive
Old Jun 9, 2009 | 03:40 PM
jjr8214's Avatar
jjr8214
Mine does that exact same thing but not all the time. I went for a couple of weeks with it working fine and then yesterday it started acting up again. After starting the truck it will only play songs by the same artist that was last playing when the truck was shut off.
I thought I had it fixed by turning off shuffle in Sync and leaving shuffle turned on in the iPod. It seems like every few days I have to mess around with Sync and my iPod to get it working. Sometimes when I start the truck the display shows that a song should be playing but I get no sound so I have to unplug the iPod and then plug it back in. Maybe it's because I have the iPod connected to a USB cable that I ran to the console from the USB2 port?
Old Jun 9, 2009 | 06:03 PM
Aztrainer's Avatar
Aztrainer
Awesome, thanks for the tip as the 500 GB WD HD is a lot chaper than any Ipod
