Distributor question for 400
Old Jun 7, 2009 | 03:07 PM
ltlvt's Avatar
ltlvt
Question Distributor question for 400
Will a distributor from a 302 work in a 400? The wires going to my distributor had the insulation melted on them due to a fire caused by a fuel leak. I have one in a 302 but don't know if it is worth the trouble to swap them . The 400 starts up fine and runs okay but has a slight off idle miss to it. I have recently refuilt the carb and put new plugs and the plug wires all look good. It has good compression on all 8 cyls and the vacum is 17 at idle and steady.. Maybe it is timed too slow. What are the timing specs for a 400. Example Static-centrifigual-vacum advance .... Todal degrees at 3500 RPM? I am eventually going to put a new cam gear and chain without the retard build into it.... Thanks...
Old Jun 7, 2009 | 06:13 PM
fordeverpower's Avatar
fordeverpower
no it won't work, different shaft for oil pump.
Old Jun 8, 2009 | 01:30 AM
grclark351's Avatar
grclark351
individual parts should swap over, just not the main shaft that runs the oil pump, or the gear.
Old Jun 9, 2009 | 01:57 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
The two applcations require different housings, shafts, and gears.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
http://performancedistributors.com/forddistributors.htm
<o></o>
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
<o></o>
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
<o></o>
Ignition Lesson of the Month: Hystereses, the difference between the timing as the rpm and vacuum increases to the timing as rpm and vacuum decrease, needs to be kept to a minimum. A precise advance curve accomplishes this.
<o></o>
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
masonandeers
19
Jan 5, 2016 03:25 PM
Jackpom
May 13, 2015 10:42 PM
Lahti35
Sep 22, 2014 06:43 PM
blueovalpaul
32
Jan 13, 2012 08:31 PM
towmater
1983 - 2012 Ranger & B-Series
Feb 18, 2007 04:27 PM
