trailer towing
Old Jun 6, 2009 | 07:58 PM
mightymouse28's Avatar
mightymouse28
trailer towing
Don't have a owners manual for my 1994 f150 supercab 4.9 liter inline 6, 5 speed manual transmission. I'm just wondering what's the most i can tow with this truck?
Old Jun 6, 2009 | 08:02 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
What is the gear ratio? That makes a big difference. If it has 2.80s or 3.08s it is not good to tow much of anything.
Old Jun 6, 2009 | 09:14 PM
mightymouse28
how do you find out the gear ratio?
Old Jun 6, 2009 | 09:15 PM
Conanski's Avatar
Conanski
There should be an axle code on the drivers door decal.
Old Jun 6, 2009 | 09:17 PM
mightymouse28
oh ok will go check right now then thanks
Old Jun 6, 2009 | 09:22 PM
mightymouse28
ok only thing it has for axle is H9 not sure what that is
Old Jun 6, 2009 | 09:28 PM
SaikotikGunman's Avatar
SaikotikGunman
3.55 limited slip, same as mine.
Old Jun 6, 2009 | 09:31 PM
mightymouse28
ok perfect now what is the towing capacity do you know? just looking at hauling a untility trl load with stuff and then the truck box full. getting ready to move so need to know thanks.
Old Jun 6, 2009 | 09:37 PM
SaikotikGunman
I pull stacked hay wagons with mine, ~6-8,000 lbs, but that's at less than 30mph. I'm hard on my stuff. But the 4.9L has plenty of low end to get going with a pretty hefty trailer behind it. Not sure what the official towing specs are for it. Many states limit you to under 3500lbs unless you're set up with electric brakes for your trailer, so that's probably going to be your real limit.
Last edited by SaikotikGunman; Jun 6, 2009 at 09:40 PM. Reason: Bad math... fixed it.
Old Jun 6, 2009 | 09:39 PM
mightymouse28
ok perfect thanks don't think i'll be too close to that but nice to know what i can roughly pull
Old Jun 6, 2009 | 09:43 PM
donnor's Avatar
donnor
towed you so...
Your H9 is a 3.55 limited slip (and still may be limited slip if it has been properly maintained & serviced; but that's for another thread...). According to the 1994 F-Series Owner Guide, the 300 5-speed is rated to tow up to 3300 pounds if 2WD, 3000 pounds if 4WD. GCWR is 7800 pounds whether 2 or 4WD.
dn.
Old Jun 6, 2009 | 09:44 PM
mightymouse28
perfect thanks for all the help guys this site is awesome so far had 2 questions and got both answered.
Old Jun 6, 2009 | 09:49 PM
SaikotikGunman
dn.
Manual specs are generally conservative...
