Just got the DRIP'S
Old Jun 5, 2009 | 01:10 PM
Bigcat350's Avatar
Bigcat350
Just got the DRIP'S
My truck for sure has a case of the drips I have cleaned it up again and hoped that it was not true or not my truck leaving the drips in the parking spots. I changed my Turbo a couple weeks ago and all was good for a while, also changed all the o-rings but I did not gut the pedestal. I just zip tied the rod to the fuel line just in case I ever wanted to hook it back up. Now just try and guess were the frigging leak is. Have you ever called yourself a dumb azz? fficeffice" /><O></O>
Well I guess I can take it all back off and clean up down there a little more and plug the rod hole. I put on the GTP 38R with the 1.15 housing so I did already delete the EBPV housing.<O></O>
Can anyone think of anything else I should do while I back in there.
I just cant stand having a leak of any type.
Old Jun 5, 2009 | 01:42 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
The only thing I can think of is, bellowed up-pipes. . This has to suck Eddie.
Old Jun 5, 2009 | 02:33 PM
Bigcat350's Avatar
Bigcat350
Yes it does. But at least I will really get it clean back there, what I didnt get the last time I will get this time.
Old Jun 5, 2009 | 02:40 PM
HKusp's Avatar
HKusp
They make a shot for that. It will stop the burning too.
Old Jun 5, 2009 | 02:48 PM
megawatt00's Avatar
megawatt00
Listen to this man...he has a medical background and is a Dr.
Old Jun 5, 2009 | 02:51 PM
miller_feed
It also could be from experience.
Old Jun 5, 2009 | 03:08 PM
Bigcat350's Avatar
Bigcat350
Thanks for reminding me Jason
I think I will take the Dr's advise and get the shot but it might be a double and burn going down. Its not going to be that bad this time I hope.
Old Jun 5, 2009 | 03:11 PM
miller_feed
You should zip right through this after just doing it. All the bolts should be easy to get off and the clamps also. I think I would change the 0-rings again.
Old Jun 5, 2009 | 04:03 PM
Bigcat350's Avatar
Bigcat350
Rick it has only been 2 weeks do you think I should still change them again. I plan on doing it this weekend so I cant get a ring kit from Bob in time but I guess I can run down to the dealer and get a set. Does the dealer have viton o-ring?
Old Jun 5, 2009 | 04:34 PM
HKusp's Avatar
HKusp
Eddie PM Ron. He had some advice regarding torque specs that he felt were better than what a lot of directions say because they torque too much and cause leaks. I can't remember what the numbers were though.
Old Jun 5, 2009 | 06:31 PM
big poppa's Avatar
big poppa
Jason made a good point, I torqued mine per Rons info, ped=20fp and 18fp turbo I think, can't remember unless I check. I noticed a light ammount of oil on my pedestal coming from above the accuater valve. Cleaned it up and i'll look again in a couple days. Before you pull everything and Ron might agree, just loosen up the turbo bolts a smidge, I think Ron did that and it stopped seeping..He'll pop on and verify..
Old Jun 5, 2009 | 06:40 PM
PaysonPSD's Avatar
PaysonPSD
Eddie said it was the EBPV actuator. No re-torqeing is going to help that.
And I agree with Mr. Miller. Bellowed uppies if you've got the change.
Old Jun 5, 2009 | 07:25 PM
big poppa's Avatar
big poppa
Man Robin, i,m batting a thousand today, thanks for the correction.. I didn't rebuild my EBPV assembly, hope its not that on mine. I,m hoping it just residule leftover from the switchout, maybe I didn't get it all, who knows, we'll see..Good luck Eddie
Old Jun 5, 2009 | 07:29 PM
Bigcat350's Avatar
Bigcat350
Its easy to see that its leaking at the actuator rod and its getting worse quick maybe because the rods in a different angle than it was for the last almost 10 years. I took it a good drive today and looked in the back with a die lite while it was running and I could see a mist of smoke coming out around the rod so I know the seal is shot. It will get fixed tomorrow if at all possible. What size Plug does it take to plug the rod hole off 1/8 or 1/4 NPT ?
Old Jun 5, 2009 | 08:11 PM
miller_feed
It depend on what you tap it to. There are no threads in the hole right now. Could be 3/8", I don't know.
