Cooling problem
Old Jun 4, 2009 | 08:40 PM
joe82ford's Avatar
joe82ford
Cooling problem
I have a 1994 f250 and I just put a radiator in the truck not to long ago the problem I am having is the radiator keeps becoming low due to that the antifreeze flows into the side reservoir but does not flow back into the radiator once the truck cools down. I also have a small leak by the thermostat would this cause this problem or is it some thing else.
Old Jun 5, 2009 | 12:25 AM
mebe2k's Avatar
mebe2k
fix the leak, then replace the radiator cap.
Old Jun 5, 2009 | 06:22 AM
subford's Avatar
subford
Also check the hose going to the side reservoir where it is attached to the radiator cap neck.
If you have a leak there it will not work, put a small hose clamp on it.
Old Jun 5, 2009 | 09:19 AM
joe82ford's Avatar
joe82ford
thanks for the ideas I will check them this weekend
