Sponsored by: Real Truck
Differental capactiy?
Old Jun 4, 2009 | 04:15 PM
MikeMcCasland's Avatar
MikeMcCasland
Hey guys, I was about to change the fluid in the front and rear diffs of my newly acquired 04 F250 V10 4x4 SRW. I have checked my Haynes manual and while it specifies what type of gear lube to use, it doesn't say the quantities it requires. With gear lube being $16 per quart I would strongly prefer to have an accurate capacity number when I go to buy the fluid.
Correct me if I'm wrong, but I believe I have a Ford 10.5 rear end and a Dana 60 up front.
Thanks!
Old Jun 4, 2009 | 05:40 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Yep, you're right, Dana 60 in the front, Ford 10.5 inch for the rear.
My owner's manual says 5.8 pints (~3 qts) of 80W-90 for the front and 6.9 pints (~3.5 qts) of 75W-140 synthetic for the rear.
Old Jun 4, 2009 | 06:25 PM
Furian's Avatar
Furian
You Keep What You Kill
You're the man Jason!
Old Jun 4, 2009 | 08:56 PM
MikeMcCasland
Jason,
Thanks so much for the quick answer. My wallet is much lighter, but I'm sure my diffs will be happier!
Old Jun 4, 2009 | 09:02 PM
1975StroppeBaja
You're welcome Mike... glad to help
and...
Thanks Andrew
