overdrive
Old Apr 15, 2002 | 10:06 PM
toyshop's Avatar
toyshop
Post overdrive
I have a 1986 f-250 2wd with 4 speed and 4.10 gears. Needless to say, at 60 mph my 6.9 oil-burner is howling away at a relentless clip. I would like to add overdrive, but don't know if the later 5 speeds are a bolt in, or if I am better off to add an overdrive unit between trans and driveshaft. If anyone has "been there, done that, and it worked" I would like to hear from you. This truck will tow occasionally, but most of the time will carry itself around with a loaded utility body on the back. Thank you, all.
Old Apr 15, 2002 | 10:11 PM
toyshop's Avatar
toyshop
Post overdrive
