Air Suspension Repair Manual
Hi if anyone has the air suspension manual can you email it to me at mudder1_2000@hotmail.com
Thanks in advance
Thanks in advance
I could get it, but I doubt it'll do ya any good...unless you happen to have a WDS or IDS or a genisys laying around. Out of curiosity, what is the truck doing? Layin' frame in the back? Front?
A lot of the air suspension work requires commanding air solenoids on and off and programming the ride height and trim checks, sometimes the first step...I know for a fact that Navi's eat compressors and front height sensors and sensor linkages (thats a TSB).
It is a 1999 Navi 4 wheel LLS. The rear is not sitting level left to right. The drivers side sits about 1 - 2 inches higher than the passenger side after air down and at trim level. Also the chk susp light keeps coming on only when I am towing my trailer. Usually after about 20 minutes of driving. It also tends to air up to high in the rear when I am towing.
The trailer is 6500 Lbs
