Wierd brake problem solved
Old Jun 3, 2009 | 04:40 PM
gr8scott72's Avatar
gr8scott72
I recently did the front brakes on my Excursion. I used Hawk Superduty pads and Power slotted rotors. Everything went well and they stopped good bet every once in a while I would get a shimmy when braking like when your rotor is warpped but it wouldn't do this everytime. I also got a slight pull to the left when braking.
I took both sides apart and cleaned the slide pins back out and regreased them. Still had the same problem. Two days ago, I started getting smoke coming out of the front wheel well when braking hard. From reading on here I knew it was probably the caliper. I went to the Ford dealership to get one but they didn't have one. The parts guy sent me to their supplier, Ryan's Automotive, and I got a loaded caliper for $92 including tax. (But with a $50 core that I got back today.) These where loaded with new slide pins, new pad spring/clip thingies, and new pads. (which I didn't use as I just bought the Hawks.)
The box said Motorcraft and the part was stamped "Ford". I couldn't believe it was only $92. Slapped it all back together then bled the line a little and took it for a test drive. All is back to normal. No more shimmy, not pulling anymore and seems to be braking even harder.
I was going to go ahead and get the left side and replace it for only $92 but they didn't have one in stock.
Old Jun 3, 2009 | 05:05 PM
Monsta's Avatar
Monsta
Sit. Stay.
Good report! Too bad we'll never know exactly what caused the other caliper to get all funky on ya...
Old Jun 3, 2009 | 08:24 PM
Stewart_H's Avatar
Stewart_H
I agree.
Stewart
Old Jun 3, 2009 | 08:42 PM
VaSheriff's Avatar
VaSheriff
Get another right one and put it on backwards.
Old Jun 3, 2009 | 09:31 PM
gr8scott72's Avatar
gr8scott72
Actually, it looks like the only difference is the outlet for the hose hook-up.
Turbo Dog
2009 - 2014 F150
Feb 8, 2017 06:01 PM
hink10
Sep 21, 2016 07:55 AM
jakgod3
Jun 21, 2015 09:50 PM
RobRoss
May 29, 2015 08:13 AM
Stewart_H
Jan 5, 2007 11:51 AM
